I have a classic commercial building with a thin layer of stucco over dense foam. I've been asked to install a pTZ camera (~12-15lbs) on an arm that holds it 2 feet from the wall.
The interior wall is finished drywall, not sure what between the foam and drywall.
I'm hesitant to do this but my idea was mount plywood or strut to the drywall, to distribute the weight. Attach bolts to the strut/plywood and penetrate the wall with the bolts. On the exterior use bolts and washers to suspend the mounting bracket 1/8" from the stucco.
I'm sure it will work, but from a liability perspective, I don't Want to be the guy that 'designed' the support system. If, it was flush to the building that's one thing. The torque created hanging out 2' is concerning.
How would you approach it? Would you want an engineering judgement?
