ptonsparky
Tom
- EC - retired
We are lucky(??) enough that we can design, layout and install, but not engineer, projects in the State. Not that I am going start on any Nuke plant layouts, but one never knows.
one of my builders put a price in for electrical, approx. 3400 sq.ft. i asked about what he figured ... $5600 told him no way :happysad:
I can make more money by not working. Zero is still more than an negative net profit.:happyyes:
My suggestion would be to select the last version of the code w/o AFCIs in them and have the GC state in writing that the install will be IAW that code version.
My suggestion would be to select the last version of the code w/o AFCIs in them and have the GC state in writing that the install will be IAW that code version. .......
ETA: I gather from a later comment the state has a minimum code you have to follow if the county has not adopted one. So, my suggestion seems like a no go.
So that would mean you would be installing to the 1999 NEC? Are you supposed to charge 1999 prices on everything also? Don't bother installing anything that did not exist in 1999 either, it may not be code compliant for 1999.
not a pricing issue. if you get a choice as to what code to comply with, you pick something reasonable that you are comfortable with and go with it.
what if the county had selected 1999 as the code they were going to enforce? would you want to spend an extra $100g installing AFCIs?
