Had to add an outdoor receptacle for transformer for outdoor low voltage lights transformer. Saw what looked like a UF cable and said no problem (already on switch with other 120 outdoor lights). When I tagged to UF cable (1962) it had only 2 wires. Put in GFI receptacle with stickers for no ground. Failed inspection.
Thought about cover plate and hard wiring transformer into 2 wire circuit. Any other thoughts?
Inspector had trouble with his little light tester, I brought up no reference, and his buddies said add-ons must be 3 wire. That would be 100 feet instead of 5 feet of work.
Would appreciate references that would save or convert my little tagged in circuit (the rest is up to code, cover, depth, protection, UF and PVC, just no ground in this older home).
Customer wants O/D light to remain on same switch/line as other lights that exist.
Virginia is on 1999, by the way.
Thanks in advance for the help!
