victor e
- Southern Cali
is this a trick question? or... does anyone know how many watts are a BTU?
No it won?t. But let?s start by being more careful with units of measure. Pierre?s answer was correct, but it did not correctly answer the original questions. The correct answer to the original questions (there were two) are, (1) ?Yes, it?s a trick question,? and (2) ?You cannot convert Watts to BTUs.? You can convert Watts to ?BTUs per hour,? and the conversion factor is as Pierre reported.Originally posted by rfrusher:The watts/BTU will be based on the temperature of the returning water.
