I am feeding a secondary building with a 480/277 volt panel fed from my main panel in the main bld. In the sub bld. there is also a sealed step down transformer 480/277to 120/240v that is feeding a load center panel for misc lights and outlets. I know by code I have driven a rod electrode outside the building and tied it into the 480v panel and also bonded the steel of the building with the same system and also pulled a grounding wire in the raceway with the feeders along with a neutral from the main bld panel and did not bond the neutral at the 480v panel. how do I tie the transformer in to the bonding system without creating a parallell installation or am i looking into this to much???
