ylmzm
- Los Altos, CA
I have a 400 Amp Square D main + meter combo (CSED). It looks like the image I attached. (Model SU3040D400CB)
It has two 200 Amp breakers. One is a disconnect for a remote subpanel, another is connected to the buss bar below it.
I plan to install a 200 Amp subpanel in the garage and another one in the house. The top disconnect will drive the house subpanel. I want to install sub-feed lugs at the bottom of the buss bar and connect the garage subpanel to those lugs. However, I could not find any square D product that can do what I want. They have some subfeed lug kits, but they seem to be installed at the top, it does not work for me.
http://static.schneider-electric.us/docs/Electrical Distribution/Pan elboards/NQ Lighting and Appliance Branch-Circuit Panelboard s/80043-729-01_trilingual.pdf
It would also be a waste of money to install a 200 Amp double pole breaker, since the garage subpanel already has its own main breaker.
Any idea how I can accomplish what I want? All I need is to tap into two phases of the buss bar with two lugs at the end.
