mstrlucky74
- NJ
Will it fit through the door or needs to be stripped?
Do you have the tools to move it? Get it off on he truck? Get it in the building?
So basically it's just bolting together 2 sections and the transformer? 2 men 2 days.
Bolting a bunch of bus bars together. 2 men 2 days, that's all?
Depends on how skilled your electricians are.
Here's a 750kva, about 7500 pounds, 4160-208/120 substation. Moved 100' around obstacles, set on the pad and bolted onto one 208/120 volt switch section which was also moved about 100'. 2 men, 1 day (Journeyman and Apprentice). Once it's on the pad we just drop it onto several 3/4 RMC rollers and move it with a pinch bar.
