Kopper
- Lewisburg, Pennsylvania, USA
- Electrical Contractor
It's likely that this question has been asked before in multiple ways and from multiple perspectives. I didn't find what I was looking for in the search that I did.
I have a customer who - about 15 years ago had a subpanel installed next to the main panel by another electrician. The grounds and neutrals were not kept separate in the new subpanel.
The situation is unique - and there is no "problem" or "issue" but I want to understand why and how this poses a potential safety hazard when there are pool circuits - or any other circuits for that matter - installed in the sub panel.
Here is the situation:
The 400A 240V single phase meter base is installed at the barn.
There is a 200A disconnect for the barn and a 200A disconnect for the house.
There are 3 wires running to the house from the disconnect - 2 phase wires and 1 neutral wire
There is a ground rod installed at the house and the main panel has the grounds and neutrals connected together
the 100A subpanel has a 3 wire with ground but the grounds and neutrals are connected together in the subpanel
I realize that this does not meet current code requirements but I am trying to wrap my head around the why of it all to better understand what I am doing when the grounds and neutrals are bonded together in a subpanel or the grounding is done at a panel downstream from the first disconnect after the meter.
For me it is important to understand the concept of what is being accomplished not just that it must be done this way cause code says so...
I understand that providing separate paths for ground and neutral is a good thing but what does it do differently than when the ground and neutral are together and why?
I hope my question is sufficiently clear to minimize unnecessary "bunny trail" answers that lead to nowhere!
