MR.DEI
- Hollister,CA
I have a 200amp sub panel fed from a 200amp breaker with 2/0 THHN. Article 240.2(B) (2) indicates if it does not correspond to the standard amperage rating the conductor can be one size smaller. Article 240.6(A) table shows 200amp as standard rating, so if 200amp is a standard should the conductor be 3/0? In the past I have always use this rule without knowing the standard rating. Can anyone clarify this interpretation?
Thanks,
Thanks,
