Smash
- Philadelphia suburbs, PA USA
I have a three unit apartment building. 200amp main service with 4 gang meter cabinet. 3 apts and a house panel. Each unit has its own panel and main disconnect. Is there any sub panels in this scenario ? Or are they each there own service. Therefore each would need its own equipment ground. Or is the house panel considered first in line and everything is a sub panel after. Therefore the equipment ground terminates in the house panel and splits ground and neutral down stream. Hope I’m explaining this right. There is no main 200amp disconnect and no where to put one if needed.
