I installed a 100amp sub panel in a detached garage that was converted into a living space. The sub panel is lug, feed from the houses on a 100amp breaker from the main panel. the inspector is telling me that i need to put a 100amp breaker in the sub to serve as the disconnect means, or install a new panel with a main disconnect. Doesn't the 100amp breaker from the main serve this purpose. I cant find any thing in the N.E.C. that states I have to have a main disconnect in my sub panel. Any help would be appreciated
