Help me understand and if there is a NEC code reference, can you direct me?
The new main panel installed is most probably rated for 200 amp. However, they only installed a 100 amp main breaker. I don't believe there is a problem with that part of the installation. FYI - It may have up to 40 spaces (most not being used).
Next, there is a sub-panel (100 amp rated, less capacity) installed on the other side of this one-car attached garage. This sub-panel is a main lug panel and they used a 100 amp branch circuit breaker to feed it from the main panel.
I don't believe this is a good practice to install this way but is there a code reference prohibiting it? Thanks for your thoughts!
