Sub-Panel Feed
Samz
What is the maximum sub-feed that is allowed off of a main panel? Say if you have a 200amp main panel what would be the maximum breaker size that could be installed for a sub-feed panel? I have looked and haven't had any luck finding this. :confused:
Re: Sub-Panel Feed
It can be any size. You won't find a specific limitation because there isn't any.
[ January 29, 2006, 09:12 PM: Message edited by: infinity ]
Re: Sub-Panel Feed
You can install as big a breaker as the panel or load center will accept.
If you had a 100 MB panel that would accept a 2000 amp branch breaker it would be permissible.
Roger
Re: Sub-Panel Feed
I thought that might be the answer I recieved, but it just didn't make sense to me. But some things just don't.
