Dmrod@NASD
- NE Pennsylvania
- Supervisor of Facilities
It has been awhile since I had to do any conductor size calculations, derating, voltage drop and such. So to simplify; my code book knowledge is way behind the times of today's NEC coded book. That said; we are constructing a storage shed and looking at installing a 100 AMP sub panel, single phase, 240volt; to supply power to the shed. My first review was leading to #4 or #2 copper. However, looking at some addition info, due to distance, suggests possibly 1/0 copper. The distance from the main panel to the sub is approx 140'. The conductor (THHN or similar) will be in sch40 conduit(pvc) buried 18". can someone quickly state what the minimum conductor size and grounding wire size would be for this distance?
