howardrichman
I'll be wiring a Endless Pool for a customer. As far as I know, NEC requirements should be the same as any permanent pool regarding outlets and motors, and bonding. There will be 2 hydraulic pumps for a treadmill, and wave maker which are supposed to have whips to install to 2 GFI 30A breakers. I'm not sure if it's permissible to install a 4 ckt sub panel for these breakers for disconnecting means. Will I need a sub panel permit and inspection before acquiring the pool permit? Are the codes similar to a spa or pool. Can I install romex to feed the sub panel or will I need to install pvc ? Will 60 amp sub feed be code for the 2- 30 amp circuits?
any info appreciated
HR...
HR...
