wireman3736
- Vermont/Mass.
There's probably been a thread on this before, In a single family house, can you run an 8-3 copper w/g romex to a two position panel then install a 50a 2 pole gfci breaker to feed the hot tub or would the ground be required to be insulated. And if this is allowed then what about using #6 ser aluminum to feed the two pos panel. Every thing I read seems to indicate that the ground has to be insulated but maybe I'm missing something.
