shaner
- Olathe, KS
There are 4 wires coming into the sub-panel in question (from the service panel on exterior of townhouse), but there is another bare copper wire connected to the ground bar that leaves the bottom of the sub-panel. Where it goes is a mystery. I'm assuming it is going to a water line connection.
Otherwise, the ground/neutral separation in the sub-panel appears correct, and service panel is properly grounded.
Can a sub-panel have a bare copper ground wire running to a water pipe connection, or some other type of secondary electrode that is separate from the service panel ground?
Thanks for your help!!
