Electricalguy
- Pennsylvania
- Electrician
I have a 200 amp meter base disconnect combo unit and I have 2 100 amp panel ran from the secondary spots on my disconnect combo unit. there is no panel hooked to the main 200 amp breaker on the combo unit just 2 100 amp double pole breakers on the secondary part. I want to run a 60 amp 240 volt power panel to my garage. what does the code say about doing this? I was going to run aluminum 4 conductor URD mobile home feed in 2" pic from the house to the garage which is about 80 feet from the house.
