hardworker
I was on a job with a 400amp main panel, that has a dozen sub-panels. I found one sub-panel, where the neutral bar and the grounding bar was connected together. I separated them as a sub-panel should be wired.
What potential problems are caused to the system by a sub-panel being mis-wired as described above?
