chevyx92
- VA BCH, VA
I had a conversation with co-worker about his plan to install two sub panels in apartment buildings and he mentioned one panel would be fed with a 2 pole 30 amp breaker and the other a 2 pole 40 amp breaker.....the loads to be served are different. I mentioned that I believed that he would have to run no less than a 60 amp feeder but I can't seem to find it in the code. Am I out in left field here or can you feed a sub panel with any size circuit you want? I for some reason thought there was something saying it had to be 60 Amp minimum. Any advice will be greatly appreciated.
