Sub panel proximity to washer machine water outlets?
utilmech
New member
Newbie here. Is there a minimum distance between water outlets for a washer machine and 125 amp sub-panel?
Installing in residential washroom.
Also, does it matter which direction a NM cable clamp connector is placed in a metallic box?
I was putting the clamp side on the inside of the box, for future needs in case need more wire loosen screws and pull slack between box and cable staple.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician, then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
