I will be installing a sub panel to a Square D 200 QO residential panel.
I pretty sure the buss stabs are rated for 100 Amp (actually reading around I think they may even be rated for 225 amp)
I'm freeing up some circuits to gain space in the main panel and move them to a sub panel, I figure 7 to 10 single pole circuits (maybe also room for future circuits which I VERY MUCH think unlikely in this house).
How would I size the panel? How would you size the panel? I see many of 60 amp sub panels around like 20 circ. Also, there are probably still hundreds of thousand 60 amp services on houses.
I figure just install a 100 amp panel and be done with it, but if I can do a 60 or 70 or 80 I would rather.
I think some 100's would have to take up 4 spaces.? Yet I vaguely remember installing a 2 pole two space 100 amp at my old house years ago.
The panel is tight and crowded and if I can use smaller conductors would help out.
Thank you
Thank you
