krussell@scs-usa.com
I saw this on another forum and I don't see any code where this is addressed.
The issue was you have a 100 Amp service to a dwelling coming into a 100 Amp Load Center.
The Home Owner want to take 80 amp service to the garage. So He install a 80 Amp Breaker in the load center then feeds a seprate load center in the garage (a "sub panel")
His Post was
I talked to an electrician about a project that I'm planning--basically the same thing--a sub panel for the garage. His comment was that the sub panel breaker can only be up to 80% of the main panel. So a 100amp panel can supply up to a 80 amp breaker. a 200 up to a 160 amp sub panel. I'm probably going to end up with a 125 amp sub running from the 200 amp main.....
The Question:
So is there a code that says the MAXIMUM size of a "sub panel" is 80% of the Main Resiential service.
I dont see it in the NEC 2008
AM I missing it?
His Post was
The Question:
AM I missing it?
