Sub panel sizing question - is this code compliant?
Bloomj
Background - I am installing solar and need to backfeed it to my service. Plan to do that via 40a 2-pole breaker.
My main service comes into a SquareD 200a CSED. This main panel supplies 4 2-pole breakers, 50,40,30,25a all for my HVAC equipment and has no more spaces. Then feed through lugs supply a panel for the rest of the home on the other side of the building.
In in order to add the 40a breaker for solar my thought was to install a sub panel next to the main service panel. Remove one of the 4 existing breakers and put in a 100A breaker and then install the breaker I removed in the new added sub panel. Then I would have room to add more circuits as needed. I would like to end up with the solar breaker, moved breaker, a single pole 15a, and a 20a 2 pole to allow me to run an energy monitor such as Sense.
Can i do this?
Thanks!
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
