I have been asked by my employer to do some electrical work at his house. I have come across a problem with a sub panel he has. His house has one main panel and 2 sub panels. The one sub panel comes off the main panel from 2 44amp breakers. The problem is that these 2 44amp breakers also supply his furnace system. Now this work was not done by a licensed electrician and i am not a licensed residential electrician. The MAIN problem is that whenever he runs his TV, irrigation system (which both run from the sub panel) and his furnace the 2 44 amp breakers trip. Now obviously there is to much current draw on this breaker. My question is why would the previous electrician wire this sub panel and furnace on the same breaker? is this not dangerous?
( how can the breaker be rated to trip if the furnace draws to much current, when the sub panel is also running of this breaker. ie what if the sub panel is fully loaded and the furnace turns on, the breaker trips, but what if the sub panel is not loaded at all and the furnace is drawing to much current will the breaker trip? most likely not) I am not sure at this time what size breaker the furnace is suppose to have but will find out soon. Anyways i am just curious if this is violating any codes? i am pretty sure it does.
Rob
Rob
