I would especially note you need an insulated EGC or "ground" wire.
If there is a pool house I bet it is a permanently installed pool.But isn't that only for a permanently install pool?
Not necessarily - read my post aboveAs well as the above advise, Please ensure there is a 4 wire feeder to the subpanel before using the subpanel to feed your feeder
.The subpanel that exists is for a pool so I am assuming it has an insulated egc. If it does not then the added panel would be in violation unless the original panel falls under 680.25(A) except. & (B)
can u run that feeder within 5 feet of the pool
680.25(A) exception will allow an existing panel to be used for pool equip. under certain situations..
I don't understand the exceptions. What do they mean?
680.25(B)(2) states that if there is an existing panel that is in a separate building that was fed with a 3 wire feeder (no egc), as previously allowed before 2008, then you can use that panel for pool equipment.
