I amRecee, are you working under a Jman or Master that can assist you?
@chorty55If his wire and circuit breakers are sized correctly, who cares if he's tripping breakers upstream? Code, no. Safe, yes. Practical, no.
Same aspect as the dummy that insisted smoke alarms need to be on afci circuits because its part of the bedroom wall/ceiling circuit. Seriously, who plugs and unplugs a smoke alarm 10x a day?
Electrician@chorty55
What is your occupation besides "mechanical"?
4th yearElectrician
Sent from my SM-S908U1 using Tapatalk
Small diversion. Back to topic.How did this go from sub panels to smoke alarms?
Ron
We need more information to know if it's "maxed out". There's nothing in the NEC to prevent you from running a 200A feeder off of a 200A panel. You should check what max allowed branch breaker is per the panel specs.I have a 200 amp service ( residential) going to a 125 amp sub panel. That subpanel feeds another 125amp panel am I already maxed out?
Certainly there's a way to disable this in settings.Sent from my SM-S908U1 using Tapatalk
Thank youCertainly there's a way to disable this in settings.
Do what the others say and do load calcs for the subpanel, main panel & service. That's the only way forward.
