Originally posted by Matt Harp:
I have installed a few 100 AMP outdoor subpanels to accomodate swimming pools and hot tubs. The 100 Amp panel provides a disconnecting means to comply with NEC, eliminates the need to crawl through the attic or crawlspace a second time when the client calls you in 6 months to add that hot tub he "might get someday", allows in ground pool installs to utilize the 240 V setup for the pump motor (I have had a few motors give me warranty trouble because they developed heat problems on 120 V), and provides a convient place to tap additional circuits for sheds, landscape lts., garages, etc.
My favorite was the couple who installed a pool in late March, then called me back to install 5 dedicated Christmas light circuits in early November. That sub panel probably saved them some money in the long run. It certainly saved me from using a great many foul words while crawling through their attic again.
