thebugbear
What are the requirements for a main breaker on a sub with 7 circuits inside a garage with the main panel being outside and within 10 feet?
I sure do agree with you there. I was a job this morning. The home inspector missed the following. Under the sink: the disposal whip was a 12" sjo terminated in a female 120 cord cap. Connected to it was a double ended male 2' extension cord pluged into the receptacle outlet under the sink. Also he missed all the sjo cables in the garage fished down in the finished walls to receptacles , and stapled to the sides of the joist in the unfinished ceiling. Don is right, if attached garage no main required by NEC for this subpanel.I do not want to do work that is just to make a home inspector feel good.
What is an MH?Originally posted by benaround:
If not attached a GES would be required in garage,unless it was a MH.
HAHAHAHAHAHAHAHAHAHAOriginally posted by jimwalker:
"What is an MH?"
They are them long box looking things sitting up on concrete blocks.Usually have about 2 foot tall grass,1 or more old cars on blocks,and a big bad dog on a chain tied to it.The guy that owns it has a can of bud in one hand rifle in other.
This is in an attached garage so why should it matter how many breakers are in the panel?6 throws are whats importand
