dvolsr1
- oak ridge tn.
i had finished putting gfci in a garage and the homeowner ask me to look at his pnl. that had been installed somewhere in the 1990s to see if everything was up to code.here is what i found .#1.a 110 v recpt. mounted as first stepped on dock and a shower mounted above it.12/2 uf or nm type underground from main pnl approx.360 ft.to 1st recpt. then exposed cable run under dock to a 2nd recpt.no gfci on either#2.two #2wire red&black with a #2 bare wire used as the gnded.conductor (netural) run in pvc &no egc pulled.In the pnl. is a 50amp 2pole bkr. and a 30amp sp. bkr.both are feeds to twist lock type outlets to pwr. boats elect.pwr. the neturals and gnds. are tied together in pnl. and a #6 bare gnd. runs from shore gnd. rod to mounting post for pnl. but is not tied to pnl. note:the plummer who put the shower in did the electrical work. After researching the 2008 code, before 1999 you did not have to isolate the netural. here is what i plan to do#1isolate netural( bare wire)and id with white tape#2replace each bkr. with a gfci type bkr.#3since there is not a egc i would tie the electrode conductor to pnl.#4 I am disconnecting the feed to the two recpts. and putting a gfci outlet at pnl . even though it may have been legal when installed i feel this change is safer especially when they used a bare wire for a netural and not isolated and around water. any comments
