Hello,
Have a project where the contractor has been careless and has left in-ground pull boxes open in an industrial environment during construction. The pull boxes are part of the new work and all of the conductors inside are supposed to be new. The boxes are large cast iron boxes that are supposed to be NEMA 4X rated (think of large junction boxes for street lighting applications). During the last 2 years the boxes have been open and have been getting filled with water and the water has been lingering for the majority of that time. The water is contaminated with oils, dirt, debris, salt (marine environment). The cable insulation is XHHW2.
If they pump out the water from these junction boxes would these cables still be fit for continued service?
I assume someone will ask what the insulation resistance reading is on the conductors (I don't have that information) - say they let the cables dry and the test comes back above NETA minimums, is there any more that can be done?
Are there any guidelines out there with how to handle flooded electrical installations?
