bkludecke
- Big Bear Lake, CA
- Retired Electrical Contractor
How would you do this? I've got to make the connections to a submersible well pump. The pump comes with tails of #14 wire and need to be connected to the well pump cable which is #6. The crimp type barrel slices the were furnished are for #6 conductors only and I have not been able to locate a splice that has a range of #14 - #6. Experience has taught me that I can probably double back the #14 a couple of times and make the crimp satisfactorily. But........... My question is about the whole listing thing and is it a violation of Art. 110.
BTW the reason for the #6 is that the well pump will be 575ft down in the casing so voltage drop was a concern with that 3 HP pump.
Suggestions?
Suggestions?
