Jdprince785
- California
What size wire and breaker is needed for a 5hp Submersible Pump.
Specs Listed Below
CentriPro
Pump Control Box
Model: CB50412CR
HP 5, Volts 230
Control Box Specs:
5 HP
230 Volt
24 Amp
3450 RPM
27.5 S.F. Max. Amp
1 Phase
60 Hertz
1.15 Service Factor
3.7 KW
Continuous Duty
KVA Code: F
Specs Listed Below
CentriPro
Pump Control Box
Model: CB50412CR
HP 5, Volts 230
Control Box Specs:
5 HP
230 Volt
24 Amp
3450 RPM
27.5 S.F. Max. Amp
1 Phase
60 Hertz
1.15 Service Factor
3.7 KW
Continuous Duty
KVA Code: F
