brother
Is there a specific code that requires transformers (actually its a combo transformer/panel unit) installed outside underground in pit/manhole, that says its required to be submersible? Having trouble finding it in article 450 NEC 2017.
We had a situation where a submersible pump had failed and the water rose high enough to short out the transformer/panel and the receptacle. The transformer/panel in the small pit only supplies that (receptacle) pump and maybe one more down to the another very small pit.
It was my understanding because of the harsh environment that the transformer had TO be of a submersible type in an underground pit/manhole that will always see water. It was also a bad design in my opinion to even have a panel/combo in this pit and the receptacle even if its a raintight type.
