TPO
- Jackson Wyoming
I have an inspector that is insisting that I install a disconnect along side a man hole that contains a submersible single phase 3-wire well motor. This is a closed system, water is pumped to an upper pond that flows down a stream to a lower pond that has a pipe into the manhole. The pump is installed in a casing inside the manhole.
I contend that it is covered by 430.102 (B) exception (a)
He contends that it is covered by 682.14 (B).
I say this doesn't apply because 682.1 which states it does not apply if covered by other articles in this Code (paraphrased).
Any thoughts.
Thanks
Any thoughts.
Thanks
