Ravenvalor
- Triad region of NC
- Electrician
Hello,
I am replacing 5 - incandescent in-ground lights encased in a concrete slab with low voltage landscape well lights. The incandescent lights are being fed with THWN inside 3/4" PVC. I plan to put 12-vac on the THWN and splice it into the cable that comes out of each low voltage well light. The existing lights are filling up with water. Apparently they are not draining properly. Would someone please recommend the best splicing method for this application? Essentially it will be THWN spliced into the cable coming out of the low voltage well light all of which will be submerged in water.
Thanks for the advice.
