publicgood
- WI, USA
I’m reviewing code sections here in Wisconsin for adding a subpanel in a dwelling unit. The current main panel is a rats nest and needs pruning. A few confirmations I’d appreciate feedback on:
1. Although not written anywhere that I know of, I expect this change is subject to the most current local code. Even simple branch circuit modifications are subject to the newest code.
2. From 210.12, to be code compliant, the new install needs AFCI as identified unless covered by an exception.
3. Although not a large cost in an overall new construction project....For the average homeowner, $25-40 per AFCI breaker plus new subpanel is very expensive. Is there anything electricians are doing to help homeowners combat costs? Typically working with the exceptions to avoid using AFCIs? Using receptacles instead of breakers, even for lighting circuits?
