c2500
- South Carolina
Ok,
I have a Seimens subpanel. It has a 100 amp main in it, though it is being fed with 90 amps. The panel feeds 3 bedrooms, a large laundry, and hallway. The bedrooms each have their own 15 amp arc fault lighting circuit, and 20 amp arc fault receptacle circuit. The 100 amp breaker is humming. When I turn off one of the 15 amp arc faults, the humming ceases. No breakers are tripping. The lighting circuit consists of cans with 60 watt bulbs installed, and for the non-can fixtures, they have 2 wire pigtails with 60 watt bulbs. Normal switches, no dimmers.
Power was just switched on, so the lighting temporary/not trimmed out to get the rest of the trades moving forward.
Is this characteristic of the Seimen's arc faults? A bad arc fault? Any other thoughts? This is the first time I have used Seimens, so I have no background with the products.
Thanks for your input.
c2500
c2500
