Stevenfyeager
- United States, Indiana
- electrical contractor
Years ago, subpanels were not required to isolate the neurtal from the ground. A customer has an older home (1980s) and apparently subpanels were not required to have neutrals isolated. One subpanel (with neutrals and grounds together) feeds another subpanel (same). I had to relocate the second sub, and I separated the two bus bars. Should I have done that? Should I 'correct' the first subpanel too? Its a 400 amp house, and has a third sub. from another main panel. Should I 'correct' it too? Usually existing conditions aren't required to be changed, but since I had to relocate the one panel, did I do right by separating the grounds and neutrals, even though its source panel is not separated? Thanks
