zbang
- Roughly 5346 miles from Earls Court
(Is this DYI? I guess it is. Close/delete as needed.)
I have the opportunity to rewire about a quarter of my house courtesy of water damage from a burst washer hose, and I'm tossing around whether to put a subpanel in the small basement under the laundry or home-run new/updated things to the panel. (I'm firmly tilted towards a panel because of breaker space.)
The service and panel (Murray, 3 open spaces, already has some tandems) is outside one corner of the house, the laundry is at the other, maybe 50' of crawlspace between them. One floor.
Right now, most of the laundry corner is on one or two circuits, including the washer/dryer, outside lights/recep's, some kitchen recep's, and maybe something in one of the bedrooms. Total mess, been meaning to update things for years, hate crawlspaces
With most of the plaster basement ceiling removed, I can now get to much more K&T wiring and see the bootleg grounds that somebody put it years ago (EGC to a cold water pipe....).
My thought is to put in a small panel (8-12 space) in the basement, run a 70-80amp 2p feed to that, and move everything I can over. No, I haven't done a load calc yet or even a survey of what I can move to a new panel. Probably new circuits for the laundry, outside lights/outlets, new basement outlet, the 'fridge, break off one of the kitchen counter sets to a new circuit, etc; basically, if I can readily get to the wiring, I move it.
Am I missing something? (right now I'm diving back into Chapter 2 for a refresher/update)
