td1236
- California
- Electrician
Does a subpanel on a firewall in the garage need fire proofing. Also, are arc fault breakers required for replacing a subpanel?
1. Residential? depends on your local codeDoes a subpanel on a firewall in the garage need fire proofing. Also, are arc fault breakers required for replacing a subpanel?
Yes, residential.1. Residential? depends on your local code
2. Not per the NEC
Ron
