Subpanel
readydave8
re member
Clarkesville, Georgia
electrician
What violations are visible in pic?
HI said working space and height of breakers, was he correct?
Says files too large so not able to post pics yet, I'll post this anyway until someone tells me how to fix
(No problem posting the pics on ET)
If this is correct orientation then it doesn't meet the rule for up is on and down is off.
No coupling on the liquid tight sleeve
Working space but the rule for existing buildings allowing less height than normal I feel shouldn't be allowed at this point.
I hadn't thought about orientation of breakers, thanks
The sealtight is sleeving romex, romex has connector where it enters box, I feel like that end is ok. Other end has Sealtight connector in handybox, so I'm not sure I'd consider romex secured
And thanks for picture magic! Maybe next you can help me with on-line Social Security form?😉
What it was installed before that rule took effect? A lot of manufacturers made them that way in the past.
When you select the picture, click on “Show picture” then click on “Actual size”, and it will give you a pop up list of file sizes you can use, then just click on the smaller file size. At least that’s how Apple works
Yes but white started late 70s. It was black, white, pink, and blue then but not standardized. Idk how to tell mc age without looking at it but I can tell old AC from newer mc and ac. When did old school AC stop being galvanized I guess.
While the manufacturers use standard colors, there is nothing in the product standard to require the use of those colors. If someone wanted to make 14AWG copper with a yellow or orange jacket, there is nothing to prevent that.
