timm333
- Minneapolis, MN
- Electrical Design Engineer
How should we determine the size (length x width) of the medium voltage substation yard at the incoming supply point of the utility? NEC does not give much information about this. The substation has 25kV pad mounted transformer and 25kV pad mounted switchgear. We can get the footprints of the equipment, and add to it the electrical fence safety clearances as mentioned in Table 110-1 of NESC. This will give us the perimeter of the fence. Is this the right way to determine the dimensions of the substation yard? Thanks.
