You beat me to the reply Bob but see my response.the electrical code does not cover flashlights.
Thanks for the responses and perspective because I was not even looking at it from an equipment perspective - was looking at the LED component and wondering if by default LEDs were considered simple apparatus as per the definition in NEC or does it have to meet the specific V/KW requirements outlined in the definition of simple apparatusFor a long time, the Scope of Article 500 (500.1) seemed to imply that Articles 500 to 504 only applied to installations. It now states clearly that they apply to equipment as well. Combine that with 2020 NEC Section 500.4 Informational Note No. 5 and Section 500.8(B), especially 500.8(B)(1) and 500.8(C), and draw your own conclusions.
Personally, I wouldn't use it.
Ok, I was always of the impression that if it was considered to be IS or NI based on meeting the criteria of simple apparatus as defined by NEC, then it did not have to be marked. Thanks for clarifying that for me.If it were IS or NI, it would have been advertised as such.
IMO NEC still doesn't apply to this simply because it is not premises wiring. Though not exactly worded that way 90.2 still kind says that NEC covers things that are installed/are a part of the premises. Some other standard for handling the hazardous location still applies though - no expert on exactly what those might be. Bottom line is in some situations you don't want anything that is potentially spark producing or that may operate above ignition point of the hazardous component whether that item is electrical or not.Ok, I was always of the impression that if it was considered to be IS or NI based on meeting the criteria of simple apparatus as defined by NEC, then it did not have to be marked. Thanks for clarifying that for me.
Equipment. A general term, including fittings, devices, appliances,
luminaires, apparatus, machinery, and the like used as a
part of, or in connection with, an electrical installation.
you are quite correct... CR2032If it has a white LED, the forward voltage would be over 1.5V; it likely runs on a 3V lithium like a CR2032 or a pair of 1.5V button cells.
Ok, I understand. Thanks for taking the time to explain.A. While Section 90.2 may be a bit ambivalent concerning equipment use versus "installations," Section 90.3 Code Arrangement states: "… Chapters 1, 2, 3, and 4 apply generally. Chapters 5, 6, and 7 apply to special occupancies, special equipment, or other special conditions and may supplement or modify the requirements in Chapters 1 through 7."
B. About the definition of equipment, but for the niggling word "installations" at the end, equipment would clearly include flashlights. Unfortunately, "installations" is not defined for the NEC, so we are left with the Mirriam-Webster, 11th Collegiate Dictionary (the official NFPA dictionary for standard terms). The route is circuitous, but the conclusion is the same: a flashlight used in a Classified Location is "installed."
That is:
Definition of installation:
1: the act of installing: the state of being installed
2: something that is installed for use
Base Definition of install:
1: to set up for use or service
If we need to dig deeper to define use, let me know.
C. While an LED may be a simple apparatus, it may only be part of an IS or NI system where a control drawing permits it.
NOTE: It is usually my habit to italicize NEC defined words and words used as words.
Noted. Thanks for the clarificationI don't see how a flashlight qualifies as "equipment".
But I would not be using such a flashlight in a classified area.
A lot of places ban anything with a battery in classified areas unless it is identified for that area.
A lot of places ban matches and lighters in classified areas too. Don't think those are covered in the NEC. But, a clear hazard.
Thanks for the guidance.IMO NEC still doesn't apply to this simply because it is not premises wiring. Though not exactly worded that way 90.2 still kind says that NEC covers things that are installed/are a part of the premises. Some other standard for handling the hazardous location still applies though - no expert on exactly what those might be. Bottom line is in some situations you don't want anything that is potentially spark producing or that may operate above ignition point of the hazardous component whether that item is electrical or not.
That little light is electrically operated. It also does not fit the scope of NEC, as part of that assembly anyway.How is a can of spray lubricant being "installed"? As mentioned what you have is a glorified flashlight that aids in seeing your point of spraying of the lubricant.
Marriam Webster
Definition of flashlight
"1: a small battery-operated portable electric light"
NEC 2017 has no references to flashlight or battery operated electri light.
The lubricant itself maybe restricted from use in a classified area but would have nothing to do with NEC persea. Restriction as a result of potential sparking of the flashlight is again not within the realm of the NEC for a flashlight.
Myself I could see this as a useful tool for mechanical work in dark recesses to help reduce overspray by helping you to target application of the lubricant.
Are we suggesting that the NEC be involved in "regulating" what is essentially a flashlight? My cat won't be happy with that if I can't use that cheap little LED laser pointer for her to chase.
Noted. Not suggesting that NEC should regulate flashlights. I misinterpreted NEC's definition of simple apparatus and was trying to rationalize the safety of the use of the LED at a component level. It's clear to me now that I cannot do that. Thanks.How is a can of spray lubricant being "installed"? As mentioned what you have is a glorified flashlight that aids in seeing your point of spraying of the lubricant.
Marriam Webster
NEC 2017 has no references to flashlight or battery operated electric light.
There are many single cell LED flashlights that operate well from a conventional 1.0-1.5V cell. I've always assumed there was some sort of current limited voltage doubler inside. I've one on my keychain with a single AAA that isn't much larger; the electronics cannot be large. I use this one, about $10 from multiple sources.If it has a white LED, the forward voltage would be over 1.5V; it likely runs on a 3V lithium like a CR2032 or a pair of 1.5V button cells.
