Suitable running boards for underground feeds
Jason H
Colorado
Journeyman
Does anyone know of accepted methods for "running boards"? 300.5 (F) I would like to give this a try for my next underground service in the mountains.
I'll be using sched40 the whole run but the mountain side is all granite and labor/delivery of sand is too costly.
Pressure treated 2x4
But I prefer sand, under and around, when digging and you find the sand you are close.
I also use the sand method for my pole lights. Once they auger the hole, you see a little white dot there. Makes it easy to find and the sand falls out easily to access the coupling.
