can i use a single recepticle for a sump pump in an unfinished basement or must i use a gfi?
D domnic Senior Member Occupation Electrical Contractor Jul 19, 2011 #1 can i use a single recepticle for a sump pump in an unfinished basement or must i use a gfi?
iwire Moderator Staff member Location Massachusetts Jul 19, 2011 #2 Under the 2008 or 2011 NEC you must use a GFCI assuming it is a 120 volt 15 or 20 amp circuit.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Jul 19, 2011 #3 If you're in New Jersey the single receptacle without GFCI protection is permitted. As Bob mentioned the GFCI requirement is for 15 and 20 amp, 120 volt devices. You could go to a 240 volt pump and use a non GFCI-single receptacle also.
