DerrickM
- Billings, Montana, USA
Good afternoon,
I got a call last Friday from our Plumber saying... "Hey, what's one thing you never put on a GFCI? It caught me off guard and I thought, what did I do now. He said, a sump pump... The GFCI must have tripped and now the crawl space is all flooded. I can't get to the pipe I'm trying to work at." So, I start to question what I did, think... Yeah I guess he's right, how would you know if the GFCI ever trips and then the sump floods the space? I read 210.8 (A) (4), and its pretty clear that crawl spaces require GFCI protection. This is a residential 4-plex type building.
I'm asking if anyone has run into a similar situation, and if you installed a basic indicating light on the outside of the building or something similar, as we work maintenance on several buildings around that area and would probably pick up on a light being on showing that it tripped down below.
There are obviously other foundation water issues, not huge, but enough moisture that GFCI was my first thought when I installed power.
As my electrical co worker said, better to be looking at a flooded crawl space then a dead body down there from electric shock.
Thank you in advance.
