Hi All,
I'm not a timer expert, so thought I'd reach out to the forum and see if anyone has any answers on this. I'm wanting to use a field start/stop station to control a sump pump, but also have an adjustable timer (let's leave any float or level switches out of this discussion). I'm wanting so that when I push start in the field, the pump will run for a length of time. The pump will stop either after the allotted time frame, or if I hit stop in the field. Whenever the pump stops, after either the cycle is complete or stop is pushed, I want the timer to "reset" back to whatever it's set to. What kind of timer would I need? Also I would think momentary or maintained start/stop switches would come into play as well. I've seen literature online about single shot, on delay, off delay, etc, but nothing I've seen so far is what I need. Thanks for any and all help!
