Re: Sump pumps below panel?
The sump pumps are completely flush with the basement floor--at the highest point--the covers. Looking at the wall I will be mounting the panel to, I can shift to one side with enough room to maintain my 30" width clearance. There will be a pvc line from each pump, but it will not interfere with my required workspace because I will actually be above only one of the sump pumps partially. I am just afraid that somewhere there is a minimum distance restriction, but I cannot find it. To move the panel to another location would dissatisfy the customer, and to leave it where it is above the sump pumps could be a costly mistake.
Also, to move the panel down the wall further from the pumps, I will compromise my max distance from the meter.
