- Tennessee NEC:2017
- Semi-Retired Electrician
I don't know what else to call a ceiling fan motor such as I found while swapping out the fan. The fan was not on a wall switch so I disconnected it hot, then put my breaker finder transmitter on the wires so I could find the breaker to turn it off.
The breaker finder sounded off so I turned off the breaker that was indicated. When I checked the fan the power was still on. So to avoid more false readings I just turned each SP breaker off, one at a time while having the HO watch my transmitter light.
None of the SP breakers controlled the fan, so I started with the 2-P breakers.
It was one of them.
I thought no big deal except it was a 30A 2-P on what I thought was #12 wire. Turns out the 12 was spliced onto #10 in the junction box. My "little voice" told me to check the voltage on the wires at the fan. Glad I did because I had 240V at the fan. The HO's husband (now deceased) took out a ceiling heater that was 240V and just used the wires and breaker for the fan.
My question is, how could the fan motor run on 240V for over 8 years? The motor was clearly marked 120V with nothing on the nameplate saying it could be wired for 240V.
It was "toast" when I took it down. The HO said she smelled something and her fan wouldn't come on so she called me to install a new one.
It was one of them.
